ArcZ's avatar
ArcZ
RAX120 Slow Internet Speed
I recently purchased RAX120v2 to replace my old fritzbox 7560. After installing and setting up the RAX120v2 my internet speed was limited to around 80-90mbps both on wire and wifi on speedtest.net. W...
  • FURRYe38's avatar
    Jul 06, 2023
    Try speed testing with Ooklas installable speed test app on the PC.
    What does the onboard speed test app show on the RAX router?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
