ehmabe
Sep 28, 2020Aspirant
RAX120 Slow Speeds Wired
My ISP service is 200 mbps DL . Currnelty with the RAX120 my speeds are around 90 DL. When I bypass the router and direct to the modem I am running 226 Mbps. This happens to the firmware 122 and up....
Sep 28, 2020Guru - Experienced User
are you testing wired/wireless?
Have you checked the cable? it seems like you're dropping from a gigabit connection to a 100mbps connection. You can check this by logging in and going to advanced-----show statistics.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
If its showing that port at 100m and not gigabit, then its time to check cables/modems/ports.
ehmabe
I am testing wired. When connected direct to my modem sb6190. My speeds are over 200 mbps
- plemansSep 28, 2020Guru - Experienced User
and what do the port statistics show?
- ehmabeSep 28, 2020Aspirant
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
5G Ethernet Link Down 0 0 0 0 0 00:00:00
WAN 100M/Full 617938 1142419 0 67067 544031 00:08:24
LAN 1 1000M/Full 899947 503200 0 431181 46258 00:45:35
LAN 2 Link Down 00:00:00
LAN 3 1000M/Full 00:45:35
LAN 4 1000M/Full 00:45:35
2.4G WLAN b/g/n/ax 1147M 8629 5253 0 2485 305 00:26:11
5G WLAN a/n/ac/ax 4803M 280762 130203 0 96113 5208 00:26:06PortStatus TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time 5G Ethernet Link Down 0 0 0 0 0 00:00:00 WAN 100M/Full 617938 1142419 0 67067 544031 00:08:24 LAN 1 1000M/Full 899947 503200 0 431181 46258 00:45:35 LAN 2 Link Down 00:00:00 LAN 3 1000M/Full 00:45:35 LAN 4 1000M/Full 00:45:35 2.4G WLAN b/g/n/ax 1147M 8629 5253 0 2485 305 00:26:11 5G WLAN a/n/ac/ax 4803M 280762 130203 0 96113 5208 00:26:06 - ehmabeSep 28, 2020Aspirant
Should the WAN status be at 100m
