welchyboy
Feb 18, 2020Star
RAX120 Slow Wifi Speeds
Hello I am needing some help! I have the RAX120 Nighthawk router and I have having super slow wifi speeds. For the one computer that I have hard wired the speed test shows around 39-48Mbps download w...
Christian_R
Feb 20, 2020NETGEAR Employee Retired
Hello welchyboy,
We are currently running a beta firmware in our private beta community that may help resolve your issues. If you're interested, please send me a private message with your serial number.
Thanks,
Christian
LeeH
Feb 27, 2020Prodigy
I have a Gig connection that provides 940Mbps download from the internet. The first 3 months with my router I got 900Mbps wireless using AX. I am now getting only 600 Mbps and at least once a day the speed slows down to less than 7Mbps. To fix the sub 7Mbps slow down I turn off Wi-Fi for a few seconds and turn it back on to get my 600 Mbps speed back. This is happening with 3 fairly new MSI laptops and a 4 year old ASUS laptop. Two of the MSI laptops came with a Killer AX Wi-Fi card installed. The other two laptops were upgraded to Intel AX cards.
I paid for premium support and worked with the techs for 4 days. They finally RMA'ed my router and sent me a brand new one. Still have the same problem. I contacted Killer support and the only thing they found was that the Netgear techs had changed my 5G channel to a non-DFS channel. In order to get a 2.4 Gbps link between the router and the client you must use a DFS channel. I was only getting a 1.2 Gbps link on a non-DFS channel but am once again getting a 2.4 Gbps link using a DFS channel. The Netgear techs did not know this when I kept asking them about only getting a 1.2 Gbps link.
None of the actions taken have fixed the problems. I also have tried turning off all 5G emitters except for one laptop and the router. No fix yet and Netgear closed the case when they replaced the router. I don't know how to get this elevated to engineering for a firmware fix (if needed).
- welchyboyMar 17, 2020Star
This is just crazy! I have never had so many issues. I was able to get things working a little smoother...reset my router a few times and left everything default. Speeds seemed much better. However there was a recent update and now everyday for some reason my internet or wifi connections completely quit and I have to reboot the router in order for it to work again. Then it would work for a day without too many issues.
- LeeHMar 19, 2020Prodigy
I have tried everything that Netgear, MSI, and Rivet Networks (Killer WiFi card) have recommended. Here is what fixed it for me.
After so much toubleshooting and changes made to the laptop I decided to wipe the active partions and use the recovery partion to rebuild the system. I tried every new firmware on the router working my way back to FW 108. It is working much better now but it still hardly ever hits 900Mbps on a speed test even though I can get 940Mbps consistently using a wired connection from the router. I usually see 740~750Mbps wireless. The spec on the RAX120 says maximum of 2.4Gbps link between the router and the client. I sometimes see 2.4 with FW 108 but mostly get 1.7 when using FW 108. I get unstable links that vary from 1.7Gbps to 960Mbps when using newer FW. Something like this happened when the R7000 came out and I bought one right after it was released. I hope that Netgear will continue to release new FW at least until we get a good stable high performance FW.
I think the RAX120 is a better solution than the RAX200 because I only have five 5G clients and it makes morsense to use only one 5G band router with a 5Gbe port instead of the 2.5Gbe port on the RAX200. I have a R7900 and never needed more than a single 5G band.
- kyleh22Apr 09, 2020Aspirant
I am having the same issues described in this thread. I'm on FW1.0.1.118. I thought something was wrong with my router so I returned it and replaced it with another unit. The new device has the same issues. I called netgear to figure out when new firmware would be released but they weren't able to give me a date.
I'm going to try to roll back the FW, does anyone know the most recent firmware that supports high link speeds that do not randomly drop to 1-2Mbps?
