welchyboy
Feb 18, 2020Star
RAX120 Slow Wifi Speeds
Hello I am needing some help! I have the RAX120 Nighthawk router and I have having super slow wifi speeds. For the one computer that I have hard wired the speed test shows around 39-48Mbps download w...
Topology
Apr 19, 2020Virtuoso
Dammann, have you confirmed that WMM is enabled on the RAX120 (ADVANCED | Setup | QoS Setup | Enable WMM settings (2.4GHz))?
dammann
Apr 19, 2020Aspirant
Yes, WMM is enabled for both 2.4 and 5.
- AsphyxiantApr 22, 2020Guide
Also running a RAX 120 w/ V1.0.1.118.
I will see the connection start w/ 2.4G connectivity, and slowly degrade to 280Mb over time. This firmware has serious problems.
Netgear when will you be addressing this? We need a stable firmware that offers consistent speeds.
- AsphyxiantApr 23, 2020GuideAfter 3 router resets today, device is back in the box and going back to Best Buy. Good luck guys.
- dammannApr 23, 2020Aspirant
I'm in the same boat, on the second router, same problem. Plus I bought two AX8 extenders. They're going back to.
