welchyboy
Feb 18, 2020Star
RAX120 Slow Wifi Speeds
Hello I am needing some help! I have the RAX120 Nighthawk router and I have having super slow wifi speeds. For the one computer that I have hard wired the speed test shows around 39-48Mbps download w...
Tofu-Golem
Mar 06, 2021Apprentice
I have a similar issue, and I'm done.
I have a RAX120 with a RAX80 acting as an access point. The 120 gets around 10% speed even over ethernet, and the 80 stopped providing WiFi at all after the last firmware update.
No more Netgear. I'm buying a router from a different brand today and throwing the Netgear routers in the garbage where they belong. I can't take this anymore.
michail71
Mar 07, 2021Apprentice
I moved on to Asus AX86U a while back. It just works to the point I've forgotten it is there. I'm using full 160 Mhz and routinely get 800 to 1200 mbps. It's half the cost as well.
I don't understand why the RAX gets such good reviews. Only way could be if people are only using 2.4 GHz channel.
