welchyboy
Feb 18, 2020Star
RAX120 Slow Wifi Speeds
Hello I am needing some help! I have the RAX120 Nighthawk router and I have having super slow wifi speeds. For the one computer that I have hard wired the speed test shows around 39-48Mbps download w...
Chichizola
Apr 17, 2021Star
But whe they don't there is no one to address the issue. It took me a couple of weeks to get mine exchanged under warranty, and after all that I got a referbished one with the same issues.
I have to say if you turn it one, change the SSID and password, and don't use any of the adverticed features, mine has worked normaly. If you add QoS settings, and/or MAC blocking once, it brakes. Not even a factory reset fixes it. I won't buy another Netgear device.
Tofu-Golem
Apr 18, 2021Apprentice
Honestly, I'm starting to wonder if Netgear's firmware programmers are understaffed or something. This can't be normal.
