welchyboy
Feb 18, 2020Star
RAX120 Slow Wifi Speeds
Hello I am needing some help! I have the RAX120 Nighthawk router and I have having super slow wifi speeds. For the one computer that I have hard wired the speed test shows around 39-48Mbps download w...
Foodfiend
May 25, 2021Aspirant
Ok, maybe you didn't read my post correctly. I didn't say it was my modem specifically, I said my modem had buggy issues known on the Internet with the Puma 6 chips, so I changed mine out to be on the safe side.
Then I posted the instructions of enabling Upstream QoS, which is what fixed the issue I had, which sounds like the issue you are having. I am going to take a guess and say that even though you have 2gb, it's probably asymmetrical. Meaning your upload speeds are slower than 2gb. You have approx 25 devices viaing for UPLOAD bandwidth and you are not prioritizing that bandwidth for your router, so it's treating every packet equally. You need to tell your router which apps should be prioritized so it doesnt get to where you start getting slower speeds due to latency created by your router working so hard. You have plenty of bandwidth but not all traffic is equal. You're essentially "capping" your apps upload bandwidth in return for consistent speed and stability. On day 3, gaming PC and Xbox running simultaneously, additional 25 devices on my Network.....no reboots, no lag since enabling Upsteam QoS. Try it...
Enable Upstream QoS and THEN run the Speedtest in that tab and it will configure the "cap" for you. Then prioritize your apps in the button below on the same screen. If the "cap" is too tight add a Meg or 2 at time till you find balance.
sjbhh
May 25, 2021Apprentice
Hi Foodfriend,
sorry - I had not read that in your previous post and Thank you for the QoS suggestion.
It is an asymmetrical line but there are no gaming or video devices connected and we do not use anything like this.
This is mainly business stuff we do, databases and so on. So our lines are way more than what we need and even though the upload is only 80Mbps - you would think that is enough for a few PCs/Macs doing basic stuff.
However, I will try the QoS for a few days and give you feedback on whether that improved the situation.
- sjbhhJun 02, 2021Apprentice
As promised the feedback on QoS.
QoS might be nice if you stream video on one device and run download on others. Probably even better for gaming.
For us, it did not do anything good apart from blocking even more devices that should not have been blocked in the first place.
The issues we had did not resolve on QoS nor has it been any better and we have switched it off after 2 days of trying it out.
On QoS itself we have so many issues this space is too small to describe all of them. If you configure services that works reasonably well.
If you run multiple services on one machine as we do on many machines and try to configure MAC address setup it is not as smooth.
It did not go well for us with massive differences between computers with no reasonable cause. Some Mac addresses completely blocked out of the blue.
- FoodfiendJun 02, 2021Aspirant
MAC addresses blocked? Multiple services on a machine? Ha....k. None of that has a thing to do with Upstream QoS. All it does it prioritize upload packets. Even if you have multiple services on a single machine, it just prioritizes the packets once they're on the router by service. Sounds like you got much bigger issues than what most people are describing here. If you have that much traffic on a 2gb asymmetrical pipe, sounds like you need a small business unit like a Cisco router. Particularly when we are discussing Citrix, as I support over 76 Citrix server infrastructure.
