NordicBastrd
Mar 23, 2020Apprentice
RAX120 Speed drops from 600-700 Mbps to 6 Mbps when using 802.11ax
So I have an issue where if I use any network adapter that has 802.11ax the speeds will just randomly drop from normal 600-700 Mbps to around 6 Mbps and in reality it really isn't even that as almost...
NordicBastrd
Oh one more thing, just disconnecting from the wifi and then reconnecting to the wifi will temporariliy fix the issue. No router reboot or anything necessary.
