NordicBastrd
Mar 23, 2020Apprentice
RAX120 Speed drops from 600-700 Mbps to 6 Mbps when using 802.11ax
So I have an issue where if I use any network adapter that has 802.11ax the speeds will just randomly drop from normal 600-700 Mbps to around 6 Mbps and in reality it really isn't even that as almost...
Mar 23, 2020Guru - Experienced User
which drive is on the AX200? the older drivers had issues.
go to intel and download the most recent for the AX200.
Also, try a factory reset and manual reinstall of the RAX200. don't install from a backup.
I've got the RAX200 and the AX200 and my speed/connections are currently fine. running windows 10
- NordicBastrdMar 23, 2020Apprentice
Yeah, my drivers for the AX200 are the latest available:
21.70.0.6
I have not yet done a factory reset, that is a huge pain to get everything set back up.
- plemansMar 23, 2020Guru - Experienced User
NordicBastrd wrote:Yeah, my drivers for the AX200 are the latest available:
21.70.0.6
it is a pain to setup everything again. But the RAX devices were manufactured before the AX spec was even finalized. They've responded favorably to full factory resets and manual installs. Sadly, its kind of the price you pay to be on the forefront of technology.
I guess, but I waited a year after this was first released before buying to hopefully have some of the bugs worked out, you know like being able 802.11ax actually working
