NordicBastrd
Mar 23, 2020Apprentice
RAX120 Speed drops from 600-700 Mbps to 6 Mbps when using 802.11ax
So I have an issue where if I use any network adapter that has 802.11ax the speeds will just randomly drop from normal 600-700 Mbps to around 6 Mbps and in reality it really isn't even that as almost...
NOiSEA
May 08, 2020Guide
Topology wrote:NordicBastrd, as a test, it may be beneficial to check if the problem occurs with other AX devices (e.g., a iPhone 11 Pro you or a friend might have available).
If the problem is isolated to the Intel AX200 network adapter, then that suggest that the root cause of the issue is with the Intel adapter and not the Netgear router.
I have 2 different AX200 adapters, 1 is built into my motherboard and the other is a PCIe one by ASUS. both have the problem so the problem is much more likely to be the Netgear RAX120 than the adapters. I have had this problem since February and no firmware update has ever fixed it.
NordicBastrd
May 08, 2020Apprentice
I have 3 different network adapters and they all have the same issue. Of course all of them are Intel AX200 chipsets...because all ax network adapters have that chipset. Surely an issue with the RAX120.
