NordicBastrd
Mar 23, 2020Apprentice
RAX120 Speed drops from 600-700 Mbps to 6 Mbps when using 802.11ax
So I have an issue where if I use any network adapter that has 802.11ax the speeds will just randomly drop from normal 600-700 Mbps to around 6 Mbps and in reality it really isn't even that as almost...
dcinca
May 13, 2020Apprentice
I had the similar problem.
It's caused by the driver of AX200
Use the Killer AX1650 beta drive, https://support.killernetworking.com/software/
install the Killer Control Center
How?
Method:https://blog.csdn.net/u014390186/article/details/103423636
It's in Chinese, but a lot of pictures to show how to do it, I think it's ok to who can't read chinese.
or you can try to search the method from google.
