bigcat1952
Mar 20, 2020Follower
RAX120 speed
My speed on the 5.0 band is what is expected (352 mbps). However on the 2.4 band it's only 60 mbps. Why?
Mar 20, 2020Guru - Experienced User
could be device related.
it could be the fact that 2.4ghz has much lower bandwidth speeds than 5ghz
it could be interference on the 2.4ghz band since its more congested than 5ghz
it could be any number of things.
Its hard to guess what your speeds should be off limited info as well as it could be more than 1 thing influencing it.
- TopologyMar 20, 2020Virtuoso
Bigcat1952, have you confirmed that WiFi Multimedia is enabled? Please see the router’s webpage at BASIC | Quality of Service | Enable WMM settings (2.4GHz).
