coyote3
Jul 26, 2019Guide
RAX120 spontaneously disabled wifi & router password
My RAX120's wifi and router password (including the default password "password") suddenly stopped working. So I reset the router password (with the serial number); when I then tried restoring the...
Surfndez
Sep 02, 2019Aspirant
Having same issue, but without moving it around. Tried a various number of configurations to see if it fixed the issue (maybe other signal sources causing problems) no luck.
Finally did a hard reset. Worked for 12+ hours, then same issue returned. Password gets wiped at router, particularly on 2.4GHz band, failed to get ip and or will not connect, and internet/no internet fluctuation often.
I'm a developer on the side, so tech savy, tried fixes on modem side as well. Not sure if this is firmware issue.
Dez
Dez
