Williaml99
Jul 07, 2019Aspirant
RAX120 ss Through port forwarding PPTP not working.
This worked on my old router but not on my new one. Forwarding port 1723 and 47 TCP and UDP to the target system. Works direct to modem and works on old router. What am I missing?
Williaml99
Forgot to include.
Firmware Version V1.0.0.84
msedhom
I'm having the same issues with port forwarding - none are working.
Also, can't access router remotely even when Remote Mangement is enabled.
- schumakuJul 10, 2019Guru - Experienced User
msedhom wrote:I'm having the same issues with port forwarding - none are working. Also, can't access router remotely even when Remote Mangement is enabled.
Your ISP does any kind of carrier grade NAT? Compare the "what is my IP address" with the IP address the router does show assigned on the Internet/WAN port - if not the same, figure.
- msedhomJul 10, 2019Aspirant
This. It was a different IP. Stupid me!
All working now.
