BioRAX120
Nov 24, 2024Tutor
RAX120 SSH access
Hi all, I have a RAX120v1 with last firmware installed ( v1.2.9.52 ) I was able to enable the telnet port so I can logn into the router via telnet terminal on port 23 My question is: being conn...
Nov 25, 2024Guru - Experienced User
Most likely not possible. SSH may required special keys that are not made public for security reasons.
BioRAX120
Nov 25, 2024Tutor
Hi and thanks for your reply.
well, I am a beginner so I don't have experience and knowhow, but reading several article on the web I see
someone did it on other netgear router, maybe having Dropbear SSH installed as server..?
Do you know if this would be possible, or any other ways
- FURRYe38Nov 25, 2024Guru - Experienced User
What other NG router model was this?
NG removed Telnet access support from most of there newer versions of FW. Though I presume one may have found alternative means to enable telnet access.
- BioRAX120Nov 25, 2024Tutor
I was able to enable telnet on my RAX120 with very last firmware running.
my problem is now, how can I activate the SSH ?
Is SSH just blocked by firewall? in case which telnet comand I can use to check, verify or evenatually unlock SSH?
Or if SSH server is not there, can I install example dropbear - lightweight SSH2 server
or any other OpenSSH?
What NG router that was mentioned being able to use SSH?
Most likely no.
