BioRAX120
Nov 24, 2024Tutor
RAX120 SSH access
Hi all, I have a RAX120v1 with last firmware installed ( v1.2.9.52 ) I was able to enable the telnet port so I can logn into the router via telnet terminal on port 23 My question is: being conn...
BioRAX120
Nov 25, 2024Tutor
there are, but running modded firmware...example the one voxel created.
Nov 25, 2024Guru - Experienced User
Ah ok, that would be why then. You'll not get SSH access with NG Stock FW.
- BioRAX120Nov 25, 2024TutorSo on original last firmware, having telnet access, there is nothing we can do to try to unlock SSH by telnet command, maybe installing a ssh sever openssh, or something similar? Changing firewall permission from telnet? Adding things via telnet? As said I'm not familiar with Linux I just would like comment from developers that maybe let me do some test?
- FURRYe38Nov 25, 2024Guru - Experienced User
