MCBurn
Oct 02, 2020Star
RAX120 Stability
Earlier this year I purchased a RAX120 and almost immediately started facing “early adopter” issues with the firmware. I attempted to work with the community in addressing the DNS issues and WiFi speed drops the hardware was experiencing. This was back on firmware .115/.118, and at the time with the transition to work from home I had no choice but to return the router in favor of something more stable.
7 months later, I see firmware .136 is current and I would like to go back to the RAX120 because of its support for WAN aggregation and a multi-gig port. Are the issues most were experiencing at the start of the year for the most part worked out? Would you consider it stable enough to rely on for teleworking without the need to reboot/reconfigure the device on a regular basis?
- Christian_RNETGEAR Employee Retired
Hello MCBurn,
Welcome back to the community! So far, our support team has received positive feedback regarding the latest firmware version.
Christian
- KillhippieProdigy
After two weeks the logs still vanish and reappear though, but that does not effect stability, it just means its hardwork diagnosing ISP/LAN/WLAN issues. <sigh>
Thanks for the feedback, all. Just picked up another RAX120 and so far, so good (*knocks on wood*). Downloads are back in the ~1200Mbps range thanks to WAN aggregation so pretty happy so long as its ghosts from the past don't reappear.
- dcincaApprentice
The most stable firmware is .108, but the signal of 2.4G is weaker than other version. No reboot, no d/c.
The newest firmware .136 has a big improvement from .122/.128, I have noticed only 2 reboots since it's out.
Well, here we are again a few days into my second attempt at running a RAX120 and back to having issues. It appears about once per day the router will fall flat on its face and connection speeds will drop to <10 Mbps until it’s rebooted.
Noticed connectivity issues arising tonight so ran a speed test (on a wired connection): ping of 211, 8.36 down, and 6.41 up.
Checked logs and rebooted. Logs were very uneventful since the last reboot to correct the same issue a couple days prior.
Upon coming back up, ran another speed test. This time is back to normal: ping of 15, 1,148.78 down, and 37.93 up.
I've attached the router log that has everything since last failure minus the DoS entries. Have also attached speed test results from minutes apart showing before and after reboot.
Any ideas? Should I try rolling back to .108? I don’t have any devices using 2.4G and have the radio disabled, so not concerned with .108 shortcomings in that regard. May just give up on this line of routers for good if it can't go more than a day or two without requiring a reboot.
