malrats
Dec 24, 2023Aspirant
RAX120 suddenly keeps turning SmartConnect ON by itself.
As of the past 5 or so days, my RAX120 has been acting really strange. It’s been working great for years so I don’t understand. My personal devices are always connected to the 5GHz band (game conso...
Dec 25, 2023Guru - Experienced User
Nobody else has seen this behavior since NG released this version of FW.
malrats
Dec 25, 2023Aspirant
I haven’t been able to do that, unfortunately, as there’s a house of people who would tear me apart for the connection being down for any length of time.
They’re going away on vacation in about a week or so, I’d have to do it then.
Is there a way to back up settings or would I have to remember what everything was set to? I’ve never had to factory reset a router before. I’ve been very fortunate.
- FURRYe38Dec 25, 2023Guru - Experienced User
- malratsDec 25, 2023AspirantThank you.
Will it be effective if I reset the router and then restore from backup? Or is the possible fix in starting with fresh settings and getting everything all set up again setting by setting from a blank slate?- FURRYe38Dec 26, 2023Guru - Experienced User
I would FR and setup from blank slate. The back up file though maybe valid, may re-introduce the problem.
Some thing to try if you want, FR then apply your back up. If you see the problem again, then you'll need to FR then setup from blank slate or scratch.
