Rogbrimb
Oct 05, 2020Aspirant
RAX120 to wirelessly bridge internet from R7000
Hi guys first post on here. I have uk sky broadband and have connected my RAX120 to the sky router with the sky router radios turned off but experiencing issues, possibly due to the double NA...
Rogbrimb
I want rid of the sky router so I can use the full set of controls that come with the Netgear. I have two decent Netgear routers but only one of them will be able to connect to the sky dsl so wanted to use the other extend the range to the back bedroom.
Oct 05, 2020Guru - Experienced User
Then try hooking the RAX120 to the sky router and put the RAX's ip address in the sky's dmz.
https://superuser.com/questions/1007399/how-to-set-up-a-dmz-on-a-sky-hub
