PatEzzo
Sep 02, 2019Aspirant
RAX120 unable to connect from computer
I have just installed a Nighthawk RAX120. I am able to connect to it with my phone, and with other phones. I am not able to see it as an available network from my Windows10 computer. My husband is ...
michaelkenward
Sep 03, 2019Guru - Experienced User
This seems to be a Windows issue rather than the router.
Is this a wifi connection from PC to router or wired?
How are you connecting to the network? With Windows's networking the WiFi bit of Network & Internet?
My first guess is that you need to tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
PatEzzo
Sep 03, 2019Aspirant
I am connecting over wifi. I will try your recommendations
Thanks
Thanks
