networkcare
Aug 31, 2020Follower
RAX120 Uplink speed is limited at 100Mbps when QoS is enabled
When QoS is enabled, uplink speed is limited up to 100Mbps. Can we raise the limitation to 1Gbps ? I tested many times and when the QoS is turned off, the uplink speed can be reached to almost 1Gbps....
skipper61717
Sep 01, 2020Aspirant
Why would you enable QoS with gigabit internet? QoS is only useful "if" you have slower internet like 30 down\3 up "and" buffering is occuring with various apps (youtube, twitch etc).
