networkcare
Aug 31, 2020Follower
RAX120 Uplink speed is limited at 100Mbps when QoS is enabled
When QoS is enabled, uplink speed is limited up to 100Mbps. Can we raise the limitation to 1Gbps ? I tested many times and when the QoS is turned off, the uplink speed can be reached to almost 1Gbps....
Sep 01, 2020Guru - Experienced User
QoS isn't recommended at speeds >300mbps according to netgears own info. Its the Note under the dynamic qos info
