networkcare
Aug 31, 2020Follower
RAX120 Uplink speed is limited at 100Mbps when QoS is enabled
When QoS is enabled, uplink speed is limited up to 100Mbps. Can we raise the limitation to 1Gbps ? I tested many times and when the QoS is turned off, the uplink speed can be reached to almost 1Gbps....
avtella
Sep 01, 2020Prodigy
QoS on Gigabit only makes sense if you have aysymetrical speeds like with my ISP Comcast which gives 1.2 Gbps/40 Mbps realworld speeds....However If you have symetrical gigabit its really gonna tax the CPU to do QoS and kinda pointless on a consumer system as most people wouldn't commonly saturate their gigabit link. You'd need an x86 AMD/Intel CPU based router or something as powerful for something like that.
