GM_FFX
Sep 01, 2022Guide
RAX120 UPNP and Port Forwarding help
I had to do a factory reset of my RAX120 and I'm on firmware V1.2.3.28. I tried to enable UPnP but none of the services kicked in (like NAS boxes external access). I tried to open ports for the s...
Sep 02, 2022Guru - Experienced User
Be sure your using the port before you use the port checker. The port has to be actively being used to get the status of it.
If you set up a Port Forward configuration, uPnP should be disabled prior as well.
I tried to open ports for the services that were open previously like FTP 21 but when I go test it from the outside the port shows as closed.
Isn't UPnP supposed to add the service automatically? What can I try to resolve this issue?
GM_FFX
Sep 02, 2022Guide
firmware V1.2.3.28
The ONT is the latest FIOS Gigabit one, it's a small black one, not the old white wall box.
As it turns out it took 8 hours for the ports to actually open and work, I wonder what caused the delay because with the previous system port forwarding was instant.
- FURRYe38Sep 02, 2022Guru - Experienced User
Odd for sure...should be instant if there being used. 🤔
