thehypnootoad
Mar 22, 2021Luminary
Rax120 usb issue
Managed to get the rax120 to run for few days on .136 really well i plugged my 2 usb harddrives in. Now nothing but issues blink cameras dropping and other cameras internet connection randomly droppin...
Mar 22, 2021Guru - Experienced User
Are they powered usb drivers?
Or running off the usb bus?
thehypnootoad
They are running of usb no external power they just like the 1 tb external hardrives you can buy off amazon for 40 quid. But my connection has gone back to normal since unplugging as when they were plugged causing connection drops wifi issues with my cameras especially.
- plemansMar 22, 2021Guru - Experienced User
If you only use 1 usb drive, do you have issues?
Wondering if its possibly a power issue with running 2x usb drives of the usb power
- thehypnootoadMar 22, 2021Luminary
Hi will give another go and report back in few hours.
- thehypnootoadMar 22, 2021LuminaryNot getting disconnection on my other cameras but with my blink clips aren't loading properly so somethings not right but soon as I unplig blink cameras go back to normal
