MalphasYiu
Jan 13, 2020Aspirant
RAX120 using Disabled DHCP as Access point are slow
Hi all, I have purchased 5 of the RAX120 one as the main router with DHCP on, and 4 as access point only with DHCP disabled. But however the wifi speed with the 4 routers are seen to be capped at aro...
- Jan 16, 2020Speedtest.net đ
Doesnât matter now, returned all the rax120 and not a fan of netgear anymore. Cheers.
Christian_R
Jan 16, 2020NETGEAR Employee Retired
Hi MalphasYiu,
May you tell us how/what you're using to run a speed test? Something to keep in mind is that your devices are provided with 90 days of complimentary support form our support team. You can contact support using the link below.
https://www.netgear.com/support/default.aspx
Christian
