RAXuser's avatar
RAXuser
Guide
Feb 22, 2024
RAX120 v RAXe500 performance
I have a RAX120 that is limiting my speed to about 940MB down.....   both my modem (arris s33) and my ISP support 1.2GB.      If I upgrade to a RAXe500 will I be able to utilize the full (or close to...
  • plemans's avatar
    Feb 22, 2024
    RAXuser wrote:
    1. To be connected to the S33's multigig port  - Completed
    2. to be connected to the RAX120's multigig port from the S33 - Do I change the below setting to 5G Ethernet port or the Wan Aggregation?
    Thank you again for your help!
    If you've connected it to the 5g ethernet port, you'll change it to that port.
    Then check the wan port statistics to ensure its connected at multigig speeds
