DannyLin
Apr 06, 2022Apprentice
RAX120 v2 - internet connection dropped once almost every week
So I got a brand new RAX120v2 via the RMA after my RAX120 was confirmed dead. Have used the RAX120v2 for about 2 weeks and it's updated to the latest firmware. One of the issues that I observed...
SkippyNL
Apr 09, 2022Guide
Hi,
I have the same issue. For me it's when i'm downloading some larger files. Also, the Router just completely reboots and it also clears out the log file. The source of download is not the problem for i've tried a few different things, and it goes alright for some a few minutes but then just goes down and the router reboots. My friend actually has the same router, and is actually experiencing the exact same phenomenon.
Personally I believe it's a firmware issue and it's got something to do with either throttling or the way it uses it's memory.
Best regards,
Skipp
Apr 09, 2022Guru - Experienced User
RAX120 v2 users, please make contact with the forum moderator here as they have a beta FW being made available for those having reboot issues with these routers:
Good Luck.
