DannyLin
Apr 06, 2022Apprentice
RAX120 v2 - internet connection dropped once almost every week
So I got a brand new RAX120v2 via the RMA after my RAX120 was confirmed dead. Have used the RAX120v2 for about 2 weeks and it's updated to the latest firmware. One of the issues that I observed...
Abrolino
Sep 25, 2022Aspirant
Hi everybody
I have the same problem and it appears randomly.
In my case I have implemented option 3. suggested by plemans. (3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features).
The Netgear has been in operation since Jan 1, 2022, at first I had a few occasional issues, but for the past month it has been very frequent. I notice it 1 or 2 times a week.
I've been using it professionally, and these issues are a serious operational problem for me.
Have you been able to fix anything?
Have a nice day
michaelkenward
Sep 25, 2022Guru - Experienced User
The problem is that one symptom can have different causes. So without knowing anything about your issue, beyond the subject on a message fro six months ago, we know nothing about your system or what is happening.
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem. The firmware version also helps.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
