Joe1234567
Jun 01, 2021Star
Rax120 v2 constant random rebooting
I have the RAX120 v2 ever since purchase it has been constantly randomly rebooting. I have been through all of netgears troubleshooting guides with and without tech support. After no solution they fin...
ericwood73
Oct 26, 2021Initiate
Same. Tried two routers with different ISPs. Tried downgarding firmware. I noticed the DoS logs so I disabled that in the WAN settings. Nothing has worked.
jrgebbie
Jan 13, 2022Tutor
Disable wmm on 2.4ghz, you'll find it under qos in a different tab.
- beachmilesJan 20, 2022ApprenticeDisabling wmm on the 2.4ghz In the advanced setup tab under quality of service seems to have helped me quite a bit. The router has been up 12 hours straight where before it wouldn't last an hour. Hopefully this is a real fix until Netgear hopefully patches this major bug.
- TN_DaveJan 24, 2022Tutor
I disabled WMM on 2.4 Ghz and 5 Ghz and didn't see a reboot for three days. I reenabled WMM on 5 Ghz cause my speed dropped to 54 Mbps when disabled and 1200 Mbps when enabled. It hasn't rebooted for five days but 2.4 gHz is down to 24 Mbps.. What a shame but most of the devices on 2.4 gHz aren't very demanding, 7 Alexa Dots, 7 Ring cameras, I do have a couple Roku devices on this too but I'll try to move them to 5 Ghz.
- FURRYe38Jan 24, 2022Guru - Experienced User
So if you re-enabled WMM on 2.4Ghz, do the reboots happen again?
