Joe1234567
Jun 01, 2021Star
Rax120 v2 constant random rebooting
I have the RAX120 v2 ever since purchase it has been constantly randomly rebooting. I have been through all of netgears troubleshooting guides with and without tech support. After no solution they fin...
Retired_Member
Mar 28, 2022jus about done with this router. Consistently reboots randomly several times a week and, sometimes, several times a day. It doesn’t look like there are any solution and Netgear offered only a couple of options then gave up. I’ve also tried most if not all of the suggestions proposed here. Unless some one has come up with something recently, looks like I’ll be shopping for a new router.
Mar 28, 2022Guru - Experienced User
Did you try disabling WMM on the 2.4Ghz radio on the router. Others have reported that disabling WMM on the 2.4Ghz radio has tempoarily solved this until a FW fix comes from NG.
- Retired_MemberMar 29, 2022
Thank you for the suggestion. Unfortunately, its been disabled for quite some tiome and the behavior of the router has been the same. Going router shopping today.
Thanks again..
- FURRYe38Mar 29, 2022Guru - Experienced User
Try a factory reset or going back to last working version of FW.
- gkokaiselMar 29, 2022Tutor
I am also experiencing rebooting. I've done every troubleshooting step in this thread and nothing is working. I am willing to keep trying but not much longer. The cheap Spectrum WiFi router so far is leaps and bounds better than this thing. So disappointing. How has this device not been recalled? I see the rebooting issue all over the internet and not just in this thread.
