dwarno's avatar
dwarno
Initiate
Jul 02, 2021
Rax120 v2 constant random rebooting
Need help i have the Rax120 v2router that i have for like 2 weeks and i am having the problem that it keep rebooting on it own constant
  • plemans's avatar
    I just seen a couple of other posts in the last week where older 1st generation amazon devices were causing users devices to reboot.
    any old firesticks/fire tvs that are on? Try shutting them (and some other amazon devices) down and see if it helps.
  • 1. Along the same line you might try powering down/disconnecting all devices and turning them back on one at a time waiting for a time for each device.  In case it could also be other devices be side Amazon that could be causing the problem.
    2. Make sure your router has the most current firmware upgrade / hot fix.
    3. Make sure all of your devices are running their most current version.
    RSlack
