derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
 The router reboots  frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor.  The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Dec 23, 2021Guru - Experienced User
Is Smart Connect enabled?
What 2.4Ghz devices do you all have connected?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- Eric35Dec 24, 2021GuideThe router can reboot because of heat as well...
Eather it's some settings 2.4ghz or heat issue.- derekcannadyJan 03, 2022Guide
It's not a heat issue. It's a system load issue- the system load shoudl not be at 75% for any reason, ever.
