derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
 The router reboots  frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor.  The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Eric35
Dec 24, 2021Guide
The router can reboot because of heat as well...
Eather it's some settings 2.4ghz or heat issue.
derekcannady
Jan 03, 2022Guide
It's not a heat issue. It's a system load issue- the system load shoudl not be at 75% for any reason, ever.
