derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Kidhack
Apr 18, 2022Star
I installed the beta last week and so far the router hasn't dropped, but will report back if it does.
Apr 18, 2022Guru - Experienced User
Thanks for letting us know.
- K3onixApr 21, 2022Aspirant
I have the same issue with my router. Can you send me the Beta firmware as well?
