derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
 The router reboots  frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor.  The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Briarchild
May 01, 2022Tutor
Rax120 has rebooted 3 times after firmware 1.2.3.33-0315. First reboot happened in 3days without any change settings.Second reboot happened in less 24 hours. And after rebooting the router couldn’t back to work just a power led light stays(router will come back to work when I press the power button and turn on) Third reboot: Then I disabled 2.4G WMM the router rebooted after about 4 days but it at least could restart regularly.
