derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
oscarkk
May 05, 2022Tutor
The router restores factory settings and still has the problem of random reboot. I hope the engineers will pay attention to this problem and solve it in the new version of firmware. A router at this price shouldn't have such a low-level problem.
oscarkk
May 09, 2022Tutor
I have the European version of the router and after testing it, I can basically determine the problem: the wireless region is changed to Australia, and the problem of random reboots occurs. If the region is Europe, the reboot problem does not occur. For your reference.
- DannyLinMay 09, 2022ApprenticeThanks. That is one thing that I also suspect.
Mine Rax120vw is made in Thailand and I’m in Taiwan. But my region has been set to America. There’s no way I can alter the region setting — don’t know why.
