derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
DarrenM
Mar 31, 2022Sr. NETGEAR Moderator
I reached out the engineering about this issue and we do have a beta firmware that may have a fix for the issue if you would like to try this firmware please send me a Pm
Thanks
DarrenM
LockwoodLakeman
May 09, 2022Aspirant
I am have been experiencing the RAX120 reboot issues. Can you send me the beta FW as well?
- UnKnOwN-SiAMay 09, 2022Tutor
Hi
Could you please email me the latest beta rax120 firmware.
restart and slow download speed problem
email: siavashplus@yahoo.com
thank you
- doctorcitoMay 10, 2022StarBeta version: RAX120-V1.2.3.33-0315.img. Did not solve the rebooting issue for me. Please let me know if there are any other beta firmwares I can try. Thanks!
