derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
DarrenM
Mar 31, 2022Sr. NETGEAR Moderator
I reached out the engineering about this issue and we do have a beta firmware that may have a fix for the issue if you would like to try this firmware please send me a Pm
Thanks
DarrenM
tr4sh80
May 17, 2022Apprentice
May I please get access to the latest beta firmware for my RAX120 router? I too am plagued by constant random reboots.
- beachmilesMay 17, 2022ApprenticeI haven't heard of any beta firmware actually fixing the problem. I thought I had it fixed when I changed my UPS to pure sine wave but the random reboots ending coming back (although less often). Only disabling the 2.4ghz WMM QOS makes this router fairly stable at the expense of much slower dummed down 2.4ghz wifi.
