derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
tr4sh80
Jun 02, 2022Apprentice
I have solved the issue. It's 100% heat related. I went to the router debug page and set the exhaust fan to "Always On." I then placed the router on top of a 140mm computer case fan for added cooling. 6 days now without a single reboot and router now stays cool.
beachmiles
Is 6 days of uptime the longest you've had? If so that's not going to tell you much.
Ive thought I had it fixed before with a clean UPS power supply with like 19 days of uptime. But then I will get a reboot like once every 4 days generally always when I am doing something network intensive like streaming 4k video. Then it will stay up for another ~14 days, so its hard to tell if you really have a fix.
But I do know that with 2.4Ghz WMM ENABLED and a NON pure sine wave power supply the random reboots happen much more often for me at a rate of around ~8 times per day which is way worse.
The firmware def has a bug which needs to be fixed.
- tr4sh80Jun 02, 2022ApprenticeAll I know is the thing was running hot. Ever since keeping it cool no issues. I know a heat dissipation issue when I see one. It was curious that the exhaust fan never seemed to come on regardless of it being obviously too hot. That I believe is a firmware issue. So until they fix it, setting fan to Always on and setting the router on top of an fan acting as an air intake seems to be doing the job.
