derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
DannyLin
Jun 02, 2022Apprentice
Only 6 days, and is this the real reason?
I doubt the heating issue in the beginning too. But I think it could be the firmware issue that needed to be fixed.
For the general design, if the machine is overheated, the CPU will usually lower its frequency to decrease the temperature.
Because it’s a soft reboot, and the machine can be working after the reboot. I guess the firmware triggers the soft-reboot under specific conditions.
ekso
Jun 03, 2022Tutor
Not only the constant reboot is breaking the viability of using this router, but V1.2.3.28 has been the latest official firmware update since when? November/December 2021? Other routers have been constantly getting updates, how many 0-day are RAX120 users being exposed just because this issue is not addressed?
I also doubt it's a temperature issue. I live in Sweden in a very stable temperature controlled apartment and I've seen the router reboot at 2am hours after most electronics in the house have been turned off by smart plugs.
