derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
beachmiles
Jun 08, 2022Apprentice
Today I verified the fan came on when checking the box to always enable fan at 192.168.1.1/debug.htm
The fan doesn't generate much airflow so you have to really be watching when enabling the checkbox otherwise it's pretty hard to tell it's on. If this turns out to be the real base problem then Netgear will need to fix the reading of the temperature sensor so it doesn't read "NaNC" and ensure the fan comes on properly at the right speed. Im guessing this hack to enable the fan to always be on only runs the fan at the slowest setting which may not be enough when the router is under a heavy system load.
nestorsamelo
Jun 09, 2022Guide
Today I got another reboot after I turned on the fan always on via debug.htm.
I do not have any additional fan, but I am using a sine wave UPS.
Also, I do have WMM enabled for both 2.4 and 5 GHz.
After the reboot, it failed to synchronize NTP with Netgear NTP server, and the logs didn't have a timestamp. After I changed the NTP server to pool.ntp.org, it synchronized, and then the timestamps appeared in the log.
- FURRYe38Jun 09, 2022Guru - Experienced User
See how well it runs with the NTP change. If it still reboots you may need additional cooling.
Also, I do have WMM enabled for both 2.4 and 5 GHz.After the reboot, it failed to synchronize NTP with Netgear NTP server, and the logs didn't have a timestamp. After I changed the NTP server to pool.ntp.org, it synchronized, and then the timestamps appeared in the log.
