derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Retired_Member
Jun 26, 2022How does one get the beta firmware.... been trying to contact anyone and I'm not getting a response... tired of randomly dropping internet I work from home and it's getting worse... if it is due to overheating why doesn't the normal menu allow you to see this stuff?
dude8370
Jun 27, 2022Star
Well, I am happy to report (so far) that adding the fan/cooler below the laptop has indeed prevented this router from the random reboots (so far.) Of course I will continue to monitor long term and report weekly here if I can.
Please reference my original post for more information on the history, however I'd like to add a few things.
- I have since rebooted many times and the "Always fan option" is NOT on. So the router is doing whatever it wants.
- The fan I am using is the AC Infinity S4 on high, underneath the router directing air flow up. (AKA flowing air from the bottom, and exhausting from the top....think of it like beefing up the stock fan....if that even does anything)
- Previously, it was impossible to copy files to the router NAS drive when a heavy load was put (copying 100gb at once.) The router would get hot. Not burning "OWWW MY HAND HOT", but it makes a person go "Whoa, that is a little toasty, does this thing cool itself?" Now it is cool to the touch, and I can't feel much heat on it at all.
Again - this is seriously to salvage whatever few years I can from this thing. I will report back long term, even though things may "seem" fixed, we need to be sure.
Maybe down the road, I will open this up and see the heatsinks and any thermal paste issues? Not sure? Thoughts on that?
- FURRYe38Jun 27, 2022Guru - Experienced User
Anything is possible at this point. Could be that there maybe some missing paste, however if the heat sink IS getting hot as well, I would presume there is paste there and just not enough internal cooling with the fan. Also seems that there is some CPU handling and usage that needs to be tune up in FW to help lower what's going on there as well. Also seems like the safety trigger temp is not activating the fan as well that needs to be fixed.
Glad the fan is helping.
- dude8370Jun 27, 2022StarFor what it's worth too, my father has the same router, but the V1 version, while i have the V2. He has 0 issues with the reboot, and I can confirm as I put it through the some rigger that would reboot mine easily. Also his V1 is just as hot running as my V2 without the help from an external fan.
It could be hardware, could be firmware. I'm not sure, but the firmware numbers are the EXACT same on the V1 and V2.- tr4sh80Jun 27, 2022ApprenticeWell then that would indicate some kind of hardware change in the v2. They probably cheaped out somewhere in the v2 version to squeeze out some more $.
