derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
JFZoidberg
Jul 27, 2022Guide
My RAX120v2 reboots numerous times every day at seemingly random times. Here is a recent example from the Logs:
[Time synchronized with NTP server] Wednesday, July 27, 2022 10:00:37
[Initialized, firmware version: V1.2.3.28] Wednesday, July 27, 2022 10:00:35
I’m running the newest firmware (V1.2.3.28). I’ve read other threads about this issue, but still haven’t gotten to the bottom of it — although I know that countless other people are experiencing the same problem.
• Is this a problem with it overheating?
• Are there settings I can use to avoid the issue?
• Is there beta firmware available that solves the problem?
Any help would be greatly appreciated! For a premium router, it’s very frustrating that I’m having this happen all the time.
- FURRYe38Jul 27, 2022Guru - Experienced User
Try enabling the ThermalFan under router IP address/debug.htm
Others reported that either this or adding a laptop cooling fan stopped the reboots from happening.
I recommend getting a laptop cooler under the router for added cooling:
Any laptop cooler can work.
- JFZoidbergJul 27, 2022Guide
Thank you, FURRYe38! I ordered a laptop cooling fan earlier today as well as enabled the router's fan. Fingers crossed that this will solve the problem, but it's still frustrating — especially since the fan would have to be reenabled whenever the router restarts.
Do you happen to know if/how I could obtain beta firmware?
