derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
_NDS_
Aug 29, 2022Apprentice
I do not want this thread and the issue to go away.
FURRYe38 what was the outcome of the investigation of the muniz_ri logs by NG? Please update us.
So far in this community it was established that:
- changing power adapter stops the RAX120V2 from rebooting for prolonged periods of time - 30 days in my case, 18 days with beachmiles, but then reboots come back
- changing the router default IP address seems to help by extending the interval between reboots. Is it true muniz_ri?
- cooling the router by permanently enabling the Thermal Fan through debug settings and adding external cooling extends the interval between reboots
- disabling 2.4GhHz WiFi WMM extends the intervals between reboots
- The beta fiirmware provided by NG via DarrenM does not seem to help. Do we know how many different versions there are?
In July 2021 mariosuper47 posted the following in the RAX120V2 random reboots thread of the time (now closed):
The RAX200 worked OK for the first few weeks with random reboots. I tried many troubleshooting steps and then I ran out of my return windows. Random reboots got worse! Basically the router failed! Contacted Netgear which was absolutely no help.
My experience with RAX200 was remarkably similar to the initial poster on this thread. I tried everything and finally gave up and bought a new ASUS router. I configured the ASUS and everything worked as represented. I put the RAX200 in a box hoping for miracles, but not expecting one. 2 months later I viewed a video where some guy took apart his Netgear router and fixed some kind of random issue. I did learn how Netgear puts devices together and how to take them apart. So I decided to take a day and see what the RAX200 looked like inside since it had no value to me as it was.
I do not RECOMMEND anyone try this but I thought that I would SHARE my discovery!
I discovered that the Power Adapter plug that powered the router seemed outsized and that it did not seem to fully insert into the socket on the router mother board . I also found the socket on the router mother board was not properly soldered and secured to the mother board (ie. it moved around - up and down). I could not fix the solder joints but I had the idea to put a non-conductive spacer between the MB and the socket module preventing it from moving up and down. It took me several hours to get this done and get everything back together because I am very much an amateur. Aftert this bit of "jury rigging", I found that the power plug would fully insert into the socket which wasn't possible before.
I decided to try the RAX200 in its former place of honor which had been taken over by an ASUS. Wow! It worked perfectly. The power adapter plug fit fully into the socket and it have been running for 2 months without a reboot. I have multi-gig internet and numerous peripherals that now work perfectly. I realize that my amatuer fix may fail at some point but I feel quite satisfied that I have gotten something out of my $500 investment and that I can once again experience network excellence.
It seems to me that quality control at Netgear has not been up to its, heretofore, high standards. Perhaps, my story of disappointment and discovery can lead to a return to quality control that has made Netgear's reputation what it is.
mariosuper47, could you please confirm that you described a problem with RAX200 and not RAX120? RAX200 does not appear to have the random reboot issue.
In Sep 2021 mkhanshaw posted the following:
Alright - With the help of these posts and my experience - I think I see the problem (literally see it).
So my rebooting started happening whenever additional load (anything over nominal compute) was happening...aka streaming (Video calls, Netflix vs Roku, etc). The additional load was creating heat. That, combined with a loosely mounted power port for the ac adapter appears to be the cause of the reboot. The loose power port also prevents you from firmly inserting the male connector...and I could FEEL the heat around this area on mine.
Although I did not take the time to disassemble my Router in an attempt to fix with a soldering iron (because my intent was just to return to amazon and be done), I DID relocate the router to a cold tile floor, add fan to conduct heat away from it...and what do you know....kept connection.
I concur that the power connector on my RAX120 is loose and does not appear to fully go in to the power socket. I imagine that when the router gets hot the connectivity may get lost just purely due to loss of electrical contact due to expansion of loose parts with heat.
FURRYe38has NG ever investigated the loose power socket issue? I can literally cause the router to reboot if I shake the cable from the power adapter.
muniz_ri
Changing the default IP address helped to eliminate the DoS entries in the log but did not help with the reboots.
But what has helped as has the potential to be a workaround is running the RAX120 in AP mode plugged into my old Linksys router. I have had this setup all weekend with no reboots so far.
- TopologyAug 29, 2022Virtuoso
Perhaps the experience of JFZoidberg on the use of the model AD2003F10 power adapter (see this thread) will be an encouraging solution to the RAX120v2 router reboot problem? Time will tell....
- _NDS_Aug 29, 2022Apprentice
Hi Topology
After DH27 posted his experience with RAX120V2 rebooting even when powered through the ADS-65MIA-19 I am not holding my breath!
After these two months I support the hypothesis that heat is causing the substandard power connector to lose contact eventually.
Otherwise I can't explain how changing the power adapter in my case removed the problem for 30 days, but not rectified it.
The heat may come from new (vs V1) Qualcomm chip and could be caused by different reasons - like excessive 2.4GHz traffic with WMM enabled, prevention of DDoS attacks that the router logs all the time, lots of 2.4Ghz clients, poor positioning etc. There is no common pattern of what people have been reporting otherwise.
The silence from NG on this topic, however, is puzzling. The problem has been reported since V2 release in Dec 2020 and we do not know if they were even able to reproduce the issue! Someone in the NG engineering division should step up to this challenge and find the root cause.
I have retired my RAX120V2 to its box for now, but may consider using it as an AP for my garden if the issue is not resolved. 😉
- muniz_riAug 30, 2022Apprentice
**Update**
I noticed that the fan was not running this morning. I checked the log and confirmed that the router rebooted overnight. There goes my hope for AP mode as a workaround.
- FURRYe38Aug 30, 2022Guru - Experienced User
Ok so tells me that the fan was working but the router rebooted. The thermal fan check box doesn't persist thru a reboot so it will default to disable during a reboot.
I'll put this in as well.
Was WMM disabled on the 2.4Ghz radio?
Was this with the beta FW installed as well?
Does disabling WMM change this?
Does the router feel warm or extra hot when this happened?
- _NDS_Aug 30, 2022Apprentice
FURRYe38In my experience the router never felt 'extra hot' enough to initate a thermal shutdown. The fan in mine was working as expected, kicking in when the router was warm to touch. With the Thermal Fan permanently on the router felt cool to touch and I have not caught it rebooting. But judging by what others said it still might reboot even when cool.
DH27it would be worthwhile chechking if unplugging and plugging back in the power connector at the back gives your any prolongred uptime.
IF you decide to check please switch the router OFF with the button at the back prior to unplugging. 🙂
I agree, heat has not been an issue. I keep the fan always on from the debug screen and that keeps the router cool.
I did more research today and read that the R700p has the same issue and the workaround was to disable mu-mimo: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R700p-reboots-randomly/m-p/2073833/highlight/true#M187147
Will try that next.
