derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
dude8370
Sep 13, 2022Star
Same here. Reboots without warning with new firmware. Factory reset and everything done as well. Factory power adapter as well. I'm thinking of opening this up and checking solder joints as replacement is close to impossible. And I've moved on to the archer ax11000.
Kubac78
Sep 17, 2022Tutor
New firmware didn't change anything. The router is still randomly reboots.
