derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Sep 20, 2022Guru - Experienced User
beachmiles Bladestorm Have you tried enabling Thermal Fan under debug page and or put a laptop cooler fan under the router? Others reported in this thread that this helped stave off these reboots.
We've make NG aware of this and they are working on it.
Bladestorm
Sep 20, 2022Star
tried to enable but after reboot it disables again. wish it would stay on too 🙂
Adding: i have even tried hanging on wall which was under AC vent. Then tried to place on shelf and elevated router so had extra space for air and still same issues.
- BladestormSep 20, 2022Star
My settings with new firmware when it rebooted about and hour and a half later. As you see load is not bad. Really do not think this is thermal issue.
- FURRYe38Sep 20, 2022Guru - Experienced User
What was going on when your RAX rebooted?
What was going on when you took this screen capture of the debug page?
What all devices do you have connected?
Does the LEDs on top of the router show any AMBER indications when this happens?
--Surfing web for answers to this issue. No other network connection
--Was checking load after pervious reboot that was about an hour and half ago.
--At the time it was my desktop and laptop, And TV but was not streaming
-- No it looks like they all go out and almost like the plug was pulled.
--Spectrum, 1gig Modem: Hitron Spectrum Cable Modem ES2251 DOCSIS3.1 2.5G eMTA
--Sad to say yes was first thing I tried.
Just note spent almost 300.00 on a useless paper weight at this time is getting old very fast.
