derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Bladestorm
Sep 20, 2022Star
Does the LEDs on top of the router show any AMBER indications when this happens?
-- No it looks like they all go out and almost like the plug was pulled.
Does the top of the router feel extra warm when this happens?
---Not sure what extra warm is to the normal standards to me no does not
--Spectrum, 1gig Modem: Hitron Spectrum Cable Modem ES2251 DOCSIS3.1 2.5G eMTA
Does this modem have a 2.5Gb WAN port?
--Yes
Sep 20, 2022Guru
Just curious what is the CAT# lan cable between the modem and router?
--Yes
