derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Bladestorm
Sep 22, 2022Star
Not to side track this but just got the RAX200 up and running. the fans on the top of that router you can feel the air being pushed. the RAX120 you could not even feel the air coming out if it or hear it working. At lease for my setup. Returning the RAX120 now.
Sep 22, 2022Guru - Experienced User
Ya, i think one of many problems with the 120v2 is that the fan isn't being triggered by default when the heat gets high.
Glad the 200 is working.
- _NDS_Sep 22, 2022Apprentice
Nope. This is yet again another deflection. The fan is working perfectly fine on my RAX120v2, however it is still rebooting randomly. Plus, quite a few people, including muniz_ri recently, reported the router rebooting even with the fan switched permanently on through the debug page in the GUI. You have seen and even replied to these posts. Being an 'experienced user' it should be blatantly obvious to you that the fan is not the root cause and cooling is not a solution. We all should know this by now.
If the was a problem with a fan on the RAX120 there would be a thread "I can never hear my RAX120 fan - is it broken?". No such thread.
Why post something that has no relevance?
