derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Oct 03, 2022Guru - Experienced User
What is the first 3 characters of the routers serial number?
Tiberius675a wrote:
Hey all, I received the RMA replacement. Fully expecting to have the same reboot issue. I was quite surprised and pleased when after unit booted and I entered setup with the browser to see I had been sent a v1 unit.
Set it up with my wifi network names and passwords. Been up for just 4 days now with no reboots.
I have seen a lot of negative comments on here regarding the support and I will say I was skeptical but I was just patient, replied with the information they requested and performed every step that asked me to take.Took about a week of going back and forth(mostly because I was busy with work and couldn't respond for a few days). I have to say I am pleased with how they handled the issue and the outcome.
Also I was expecting a brown box replacement but this appeared to be a new unit in full retail packaging including shrink wrap with all accessories. Also the power supply is the same as I received with the v2 that I returned.
Tiberius675a
Oct 03, 2022Star
v1 is 5VE
v2 was 6JY
- FURRYe38Oct 03, 2022Guru - Experienced User
Thank you. Yes, There are 3 sets of SNs for v2s, all others are v1s.
Thanks for confirming.
Tiberius675a wrote:
v1 is 5VE
v2 was 6JY
- _NDS_Oct 08, 2022Apprentice
Looks like another month down the line and still no resolution from NG on the random reboot issue. Those in the USA with the router within warranty - have your requested hardware support to exchange for RAX120V1?
- dude8370Oct 08, 2022Star
I was inspired to finally give do an RMA for my paperweight v2. Behold, like others I received a brand spanking new v1 unit. Set it up just like the v2 and 2 days no drops so far.
Couple of Notes. Power supply units are IDENTICAL. same model number and specs. Routers are also identical in size and shape, actually v1 seems a touch heavier. Left photos is the v1 and right photos v2. I'm hopeful the stability of the v1 will behave like the other v1 in our family.
- muniz_riOct 08, 2022Apprentice
How long is the warranty period? I purchased mine in April 2022.
For me, It was 1 year after activation. You Should Be Good. Took about 6 days from inquiry to router replacement at my door.
